TwinTurbo.NET: Nissan 300ZX forum - You wont use pin 25
Subject You wont use pin 25
Posted by -Grimm- on November 07, 2013 at 2:17 PM
  This message has been viewed 308 times.
In Reply To Re: Re: wastegate actuator pins? posted by krstull93 on November 07, 2013 at 12:11 PM
Message Just use any switched power source to power a relay.
From AEM Installation Manual:
Operating Voltage: 12VDC
Operating Frequency: 31hz
Duty Range: 10 to 90%
Max Pressure: 120 PSI
Electrical Connection: Polarity is unimportant. Hook
one wire to switched 12 Volts and the other to the AEM
EMS’s PW2 output or the driving devices boost control
line. NOTE: on the SRT4 EMS 30-1510 PW2 outputs +12V.
Hook up one wire to PW2 and one wire to ground.
If you are not sure please refer to your EMS instructions/pin
out sheet and verified the polarity output on PW2.
When energized, ports 1 & 2 are connected, when
de-energized, ports 2 & 3 are connected. The port
numbers are clearly noted on the solenoid body.
They also note:
Port 1: Sintered Muffler (would have come with the kit)
Port 2: Wastegate
Port 3: Boost Pressure
