TwinTurbo.NET: Nissan 300ZX forum - Re: wastegate actuator pins?
Subject Re: wastegate actuator pins?
Posted by -Grimm- on November 07, 2013 at 11:58 AM
  This message has been viewed 248 times.
In Reply To wastegate actuator pins? posted by krstull93 on November 07, 2013 at 10:25 AM
Message Pin 25 is the boost solenoid wire used to activate safety boost.
Are you saying that you are removing your aftermarket boost controller to return to stock? If so, then yes wire pin 25 to the boost solenoid (both sides), but according to the ECCS it looks like the solenoid is ground activated (other pin is +12V)
