TwinTurbo.NET: Nissan 300ZX forum - That demon of a line. Well the main issue I had with it is
Subject That demon of a line. Well the main issue I had with it is
Posted by LivinTheDream on November 06, 2013 at 5:42 PM
  This message has been viewed 147 times.
In Reply To PS return hard line removal posted by Zeke21 on November 06, 2013 at 09:27 AM
Message that it magically leaked where the hoses clamps to it at each end. I dont know why you want to remove yours or say replace it???? If your concerned about the rubber section leaking where it connects to the reservoir you can by a replacement hose. The crimp needs to be cut where the hardline meets the rubber section. This allows you to pull the rubber bit off and replace it.
Now if like me your feed up with those damn clamps and rubber hose you can switch over to -AN fittings and braided line. I havent removed the hardline bit as yet but Im sure I'll be cutting it up a bit.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
