TwinTurbo.NET: Nissan 300ZX forum - The boost solenoids are only activated when in safety boost
Subject The boost solenoids are only activated when in safety boost
Posted by ThisIsSparTTa on November 06, 2013 at 8:51 AM
  This message has been viewed 166 times.
In Reply To Just saying I switch my old stock lines a long time ago posted by LivinTheDream on November 05, 2013 at 11:40 PM
Message The boost solenoids are only activated when in safety boost, which should happen very rarely. They should normally be left open by the ECU to flow the normal amount of pressure to the wastegate actuators. When in safety boost, they pass through a different path to allow the wastegates to see the unrestricted air flow, so the wastegates will open at 6-7PSI as they were designed to do.
