TwinTurbo.NET: Nissan 300ZX forum - Re: Idle Issue
Subject Re: Idle Issue
Posted by TheDevilZX on November 06, 2013 at 6:52 AM
  This message has been viewed 156 times.
In Reply To Idle Issue posted by MIKEYNISM017 on November 06, 2013 at 03:25 AM
Message +1 on Rasta, if you didn't set and check the voltage at idle and open throttle to the TPS, you might want to check this out:
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/960871/How-to-test-and-adjust-your-TPS-switch-amp-sensor.html ]
If that doesn't help out, and if you're like me and tend to disconnect more than necessary for any given job, try to look for loose connections/uncoupled compression clips on hoses/loose vacuum lines etc. I forgot a vac line on the balance tube "prvr i think" and it would NOT idle of course.
Start small and re-calibrate your TPS.
