TwinTurbo.NET: Nissan 300ZX forum - Re: Idle Issue
Subject Re: Idle Issue
Posted by Rasta420 on November 06, 2013 at 4:39 AM
  This message has been viewed 153 times.
In Reply To Idle Issue posted by MIKEYNISM017 on November 06, 2013 at 03:25 AM
Message any boost/vacuum leak could contribute to idle issues, what is the TPS set at? you mentioned that you replaced it but didn't state if you set it to .45, i would do a boost leak first thing and check for vacuum leaks second thing, then go from there, i would also get the car up on jacks and see if the alignment tech was telling the truth about the crack in the turbo inlet pipe
Rasta420
