TwinTurbo.NET: Nissan 300ZX forum - It's hard to pick up a spot in the engine bay
Subject It's hard to pick up a spot in the engine bay
Posted by -Grimm- on November 05, 2013 at 4:14 PM
  This message has been viewed 145 times.
In Reply To Re: Why not just install another relay? posted by Barthur on November 05, 2013 at 04:03 PM
Message Because everything is fused (and/or has fusible links).
If you add 15A onto any of those you risk blowing the fuses. Putting in a larger fuse is a bad idea because then you will overload the wiring.
The best bet is to put a new wire in from the battery (fused) to a new relay (mounted wherever, if you can pick up a relay from a relay box on a junk Z you can put it in the relay box), then pick up an ignition wire from the relay box to activate your new relay.
