TwinTurbo.NET: Nissan 300ZX forum - 6psi, because i took off boost sensor?
Subject 6psi, because i took off boost sensor?
Posted by Basedd_z32tt on November 04, 2013 at 11:31 AM
  This message has been viewed 215 times.
Message my gauge cluster did not work when i first got my car.
So i decided to switch gauges and throw in a boost gauge.
Problem is i am only getting 6psi. Did a leak down test fixed a couple of small leaks, still only 6 psi.
Then I learned about the boost solenoids. are they powered by the Boost sensor? (i deleted that) is that what probably has powered off the solenoids and running 6psi?
any help would be appreciated!! thanks
