TwinTurbo.NET: Nissan 300ZX forum - Yup... & keep the tools to replace those parts in the Z.
ThunderZ
on November 03, 2013 at 12:29 PM
Re: This is where I'd start too. If that doesn't do it, swap
posted by iamdan012
on November 02, 2013 at 09:14 PM
I also carry spare plugs, coil, belts, hoses, coolant, vinyl gloves, fuel pump, booster cables, connectors, etc... and old clothes.
I am at wits end with my dream car, help?
iamdan012
15:21:36 11/02/13
A Z32 specialty shop will be money well spent.
zellamay
15:33:08 11/02/13
Re: I am at wits end with my dream car, help?
iamdan012
20:23:09 11/02/13
Swap out the ecu for a known working one...
280ZuL8R
20:35:16 11/02/13
ThunderZ
21:08:26 11/02/13
iamdan012
21:14:07 11/02/13
Yup... & keep the tools to replace those parts in the Z. -
ThunderZ
12:29:38 11/03/13
A bad MAF will not throw an ECU code if signal is in range
Zvil (FL)
20:46:18 11/02/13
Re: A bad MAF will not throw an ECU code if signal is in range
iamdan012
21:09:54 11/02/13
Well here's what happened to me
Zvil (FL)
18:22:53 11/03/13
* all the compenents tested "perfectly" according to the FSM
Zvil (FL)
18:25:52 11/03/13
Rasta420
06:16:43 11/03/13
I agree with Rasta... see these links for good guides
Medallion Man
08:18:10 11/03/13
Re: I agree with Rasta... see these links for good guides
iamdan012
14:10:37 11/03/13
Re: Re: I am at wits end with my dream car, help?
iamdan012
14:09:13 11/03/13
it could be your engine harness
300ZMang
14:21:55 11/03/13
Re: it could be your engine harness
iamdan012
15:18:04 11/03/13
Re: Re: it could be your engine harness
Rasta420
15:19:40 11/03/13
brittle, splice and solder... sounds like a possible answer! (n/m)
300ZMang
16:00:14 11/03/13
is it a hot vs cold hesitation?
300ZMang
16:17:11 11/03/13
Re: is it a hot vs cold hesitation?
iamdan012
18:14:40 11/03/13
Re: Re: is it a hot vs cold hesitation?
Rasta420
06:33:32 11/04/13
Re: Re: Re: is it a hot vs cold hesitation?
iamdan012
18:16:08 11/04/13
iamdan012
15:48:22 11/03/13
Re: Re: Re: I am at wits end with my dream car, help?
Rasta420
16:59:08 11/03/13
Have you performed the power balance test?
doug8867
10:52:02 11/03/13
just to confrim.. have you checked / replaced the igniter
Medallion Man
03:40:42 11/04/13
Have you checked fuel pressure?
WhiTTe Z (NY)
16:46:16 11/04/13
Re: Have you checked fuel pressure?
iamdan012
18:17:21 11/04/13
Re: Re: Have you checked fuel pressure?
Rasta420
18:28:56 11/04/13
Re: Re: Re: Have you checked fuel pressure?
iamdan012
12:21:18 11/05/13
TheDevilZX
07:12:32 11/06/13
