TwinTurbo.NET: Nissan 300ZX forum - try loosening the cam caps to verify the valve height
Subject try loosening the cam caps to verify the valve height
Posted by aliaZ on November 03, 2013 at 7:30 AM
  This message has been viewed 156 times.
In Reply To Setting valve height with motor in car?? posted by MaxxAction on November 01, 2013 at 08:48 PM
Message If the valve seals up then the cam caps are loosened, valve stem height is your issue.
The only thing you could try as an interim fix if to machine the lifter where it contacts the valve stem. I'd only take off the minimum to get the valve to seal. The risk here is that you'll machine through the nitrided surface of the lifter into softer material, which will cause the lifter to fail.
