TwinTurbo.NET: Nissan 300ZX forum - Setting valve height with motor in car??
Subject Setting valve height with motor in car??
Posted by MaxxAction on November 01, 2013 at 8:48 PM
  This message has been viewed 365 times.
Message Ok guys...
just got my motor redone, and after about 300 miles I got good compression on 5 cylinders. Number 4 is at 90 psi, and adding oil made no difference. So a leak down test revealed that the cylinder is leaking back through the intake valves.
When the heads were done, the cams didn't go with them, so I am assuming they were just put back together without any consideration of valve height.
Can the top end of the motor be pulled apart and valve height set without pulling the motor out and apart again?
