TwinTurbo.NET: Nissan 300ZX forum - Re: PCV Re-route Question
Subject Re: PCV Re-route Question
Posted by Mrfairlady on November 01, 2013 at 10:25 AM
  This message has been viewed 260 times.
In Reply To PCV Re-route Question posted by DJK-West on October 29, 2013 at 06:51 AM
Message Not to HiJack,
But Im in the same boat. Mine started Doing this after I pulled my motor,deleted a Bunch of stuff and re-gasketed Everything (minus the Headgaskets and valve stem seals) and I did the PCV re route too - and my smoke is either That,..or my turbos are burning off pooling oil and Need to be replaced?
Mines a Blueish/white smoke (On Decel or only after about 2-3mins of idle or crusing.
a Tech mentioned he would see that On Mitsubishi's when those Turbo seals would Go....though, no leaks.Havne't Pulled Downpipes yet to check.
Subscribed for info.
*I used 2 new OEM PCV's as well and 2 new hoses from nissan.
Ive also Read Gutting the cats or changing to Hi flow Mid pipes change backpressure that can cuase the Turbos to leak all of sudden.Because Mine didn't smoke like this.
