TwinTurbo.NET: Nissan 300ZX forum - Not if your scan program says 25*, it must read 15* also
Subject Not if your scan program says 25*, it must read 15* also
Posted by ttsmokin on November 01, 2013 at 10:20 AM
  This message has been viewed 207 times.
In Reply To Re: Re: Check your TPS Voltage.. posted by Rasta420 on November 01, 2013 at 10:06 AM
Message Then yes move the CAS until you see 15*, use the coil pack wires leading to cylinder #1 for best results. Even better is to make a jumper spark plug lead between the #1 spark plug and its coil pack, this will give the most accurate timing readings with the light.
