TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Check your TPS Voltage..
Cjw3
on November 01, 2013 at 10:17 AM
posted by Rasta420
on November 01, 2013 at 10:06 AM
If the ECU is reporting .4 volt, and the timing at 15*.. then it is in Idle Mode.. so the CAS is putting the Timing at 23*.. need to twist the CAS to get the Car actually at 15* and all will be right with the world..
Cj
Timing question
Rasta420
19:03:14 10/31/13
Yes. You check for 15 by clipping the looped black wire
ThunderZ
19:26:31 10/31/13
Re: Yes. You check for 15 by clipping the looped black wire
Rasta420
20:20:48 10/31/13
Re: Re: Yes. You check for 15 by clipping the looped black wire
Rasta420
20:21:40 10/31/13
Yes. (n/m)
ThunderZ
20:29:24 10/31/13
Re: Timing question
Rasta420
20:28:01 10/31/13
Cjw3
21:09:12 10/31/13
Rasta420
07:26:24 11/01/13
Rasta420
10:06:56 11/01/13
Re: Re: Re: Check your TPS Voltage.. -
Cjw3
10:17:22 11/01/13
Re: Re: Re: Re: Check your TPS Voltage..
Rasta420
10:19:36 11/01/13
Not if your scan program says 25*, it must read 15* also
ttsmokin
10:20:21 11/01/13
Re: Not if your scan program says 25*, it must read 15* also
Rasta420
10:26:33 11/01/13
Re: Re: Not if your scan program says 25*, it must read 15* also
Rasta420
10:35:52 11/01/13
