TwinTurbo.NET: Nissan 300ZX forum - Nope... I have to find a lil bit of time.
GitNMyBelly
on October 28, 2013 at 10:14 PM
did u figure it out yet? (n/m)
posted by 300ZMang
on October 27, 2013 at 09:46 AM
Im gonna pull the plenum and pull injectors. everything seems to be pointing to ethanol killing my old style injectors.
What kills injectors?
GitNMyBelly
19:42:13 10/24/13
constant 12v being supplied is a theory
300ZMang
22:29:58 10/24/13
Re: constant 12v being supplied is a theory
GitNMyBelly
00:04:46 10/25/13
could be the coil switch out with the high ohm >>
ZUL8TR
05:49:21 10/25/13
Re: could be the coil switch out with the high ohm >>
GitNMyBelly
12:10:36 10/25/13
You said a cylinder isn't firing.
300ZMang
12:22:21 10/25/13
Re: You said a cylinder isn't firing.
GitNMyBelly
12:38:03 10/25/13
300ZMang
09:46:04 10/27/13
Nope... I have to find a lil bit of time. -
GitNMyBelly
22:14:13 10/28/13
ethanol kills old style injectors
ThisIsSparTTa
08:25:17 10/25/13
2nd on all fronts. (n/m)
spicyZ
08:41:13 10/25/13
Moving to the 740cc Nismo injector questions...
GitNMyBelly
12:08:56 10/25/13
Re: Moving to the 740cc Nismo injector questions...
ThisIsSparTTa
12:47:31 10/25/13
My experience is not consistent with your post.
ThunderZ
17:01:48 10/25/13
4 years ago I upgraded all to 93+ new style injectors >>
ZUL8TR
11:25:42 10/27/13
What were signs that your injectors were going bad?
GitNMyBelly
22:18:17 10/28/13
Check the auto FAQ - there are several links, with updates
spicyZ
08:17:15 10/30/13
If you upgrade to new type injectors also grind the >>>
ZUL8TR
11:32:10 10/27/13
