TwinTurbo.NET: Nissan 300ZX forum - fuel pressure question
Subject fuel pressure question
Posted by charleyd on October 27, 2013 at 10:06 PM
  This message has been viewed 168 times.
Message I am so confused. I was checking fuel pressure on my '91 NA. Pressures at idle seem normal per the fsm, but the pressure steps up when RPM is increased. This happens even with the vacuum hose to the fuel pressure regulator disconnected. I read that the ECU steps up voltage to the fuel pump (Ash's 6 P's describe this.), apparently as a function of engine RPM. But how does the pressure increase (regardless of pump flow) if there is a regulator that only knows about 1) supply pressure and 2) vacuum and should always maintain a constant delta-pressure between these? I would have to think that in this situation, the regulator is not doing what's it's supposed to do. Any explanations?
