TwinTurbo.NET: Nissan 300ZX forum - I would not run it any longer...
Joe@ZSpeedperformance
on October 26, 2013 at 10:50 PM
Supercharger whine coming from intake sprockets after 120k
posted by PDTT
on October 25, 2013 at 09:30 PM
It sounds like a bad bearing in one of the idlers, Are you sure the belt is not too tight? Did you take the small bolt out of the tensioner?
PDTT
21:30:32 10/25/13
Same noise..
GotTwins90
00:14:25 10/26/13
I had the same noise..
xpwarrior
08:09:12 10/26/13
Re: I had the same noise..
PDTT
09:53:26 10/26/13
Yes up against the lip on the exhaust sprockets.
xpwarrior
20:06:24 10/26/13
Where was the t-belt sourced from? Only thing that
jzack
10:10:36 10/26/13
Re: Where was the t-belt sourced from? Only thing that
PDTT
11:02:59 10/26/13
UPDATE: Video
PDTT
18:57:02 10/26/13
Mine did that also. It was the timing belt idler pulley
scottmt21
21:03:06 10/26/13
I would not run it any longer... -
22:50:52 10/26/13
Re: I would not run it any longer...
PDTT
12:37:10 10/27/13
Re: Re: I would not run it any longer...
tumevain
12:54:40 10/27/13
