TwinTurbo.NET: Nissan 300ZX forum - Mine did that also. It was the timing belt idler pulley
Subject Mine did that also. It was the timing belt idler pulley
Posted by scottmt21 on October 26, 2013 at 9:03 PM
  This message has been viewed 240 times.
In Reply To UPDATE: Video posted by PDTT on October 26, 2013 at 06:57 PM
Message between the intake pullys. I drove it for 1000 miles like that and put a new one on when I did the belt. Definatly look into replacing it as it is a good indicator of a bearing failure. Did you replace the Idler pullies when you did the 120k? if so you might have gotten a bad one which SUCKS! If you pull it apart you should also replace the idler studs with the Ramyz ones.
