TwinTurbo.NET: Nissan 300ZX forum - Let's see if I can help:
Subject Let's see if I can help:
Posted by zellamay on October 25, 2013 at 6:56 PM
  This message has been viewed 257 times.
In Reply To Decking block and cam timing.. posted by MaxxAction on October 25, 2013 at 04:05 PM
Message Following the belt, starting at the crankshaft, you lose .015 before the d.s. exhaust cam. If the crankshaft sprocket is 3" dia (I'm guessing), that's about .6 deg, measured at the crank. There's no change between int/exh cams on either side. Then you cross the line twice to get to the p.s. cams. If cam sprockets are 6" dia, then you lose about .6 deg measured at the p.s. intake cam. So, if I'm correct, that's a total of approx. 1.2 deg retard at the worst point, the p.s. cams. I don't know how crucial that is on this engine.
