TwinTurbo.NET: Nissan 300ZX forum - Instructions with the rail says to immerse it in
Subject Instructions with the rail says to immerse it in
Posted by ZTicket(Dallas) on October 25, 2013 at 5:47 AM
  This message has been viewed 157 times.
In Reply To Boost testing 300degree rail o-rings while motor is out? posted by Jkova300z on October 23, 2013 at 03:44 PM
Message a bucket of water with air attached and to look for bubbles. This would find a leaking O-Ring. However, the seal to the lower plenum is provide by the "insulators". To check this without the Plenum attached requires you to make a fixture that screws down to the lower plenum & you apply air and listen for leaks. Got the idea from a guy on the forum. Maybe he'll post the same pics that I used to make mine.
