TwinTurbo.NET: Nissan 300ZX forum - Re: constant 12v being supplied is a theory
GitNMyBelly
on October 25, 2013 at 12:04 AM
posted by 300ZMang
on October 24, 2013 at 10:29 PM
Yeah I did have a battery tender, on it the whole time. Apparently that wasn't good for my battery either... But what's strange is the cylinder that is opposite the high ohm cyl is the one that's not firing.
What kills injectors?
GitNMyBelly
19:42:13 10/24/13
300ZMang
22:29:58 10/24/13
Re: constant 12v being supplied is a theory -
GitNMyBelly
00:04:46 10/25/13
could be the coil switch out with the high ohm >>
ZUL8TR
05:49:21 10/25/13
Re: could be the coil switch out with the high ohm >>
GitNMyBelly
12:10:36 10/25/13
You said a cylinder isn't firing.
300ZMang
12:22:21 10/25/13
Re: You said a cylinder isn't firing.
GitNMyBelly
12:38:03 10/25/13
did u figure it out yet? (n/m)
300ZMang
09:46:04 10/27/13
Nope... I have to find a lil bit of time.
GitNMyBelly
22:14:13 10/28/13
ethanol kills old style injectors
ThisIsSparTTa
08:25:17 10/25/13
2nd on all fronts. (n/m)
spicyZ
08:41:13 10/25/13
Moving to the 740cc Nismo injector questions...
GitNMyBelly
12:08:56 10/25/13
Re: Moving to the 740cc Nismo injector questions...
ThisIsSparTTa
12:47:31 10/25/13
My experience is not consistent with your post.
ThunderZ
17:01:48 10/25/13
4 years ago I upgraded all to 93+ new style injectors >>
ZUL8TR
11:25:42 10/27/13
What were signs that your injectors were going bad?
GitNMyBelly
22:18:17 10/28/13
Check the auto FAQ - there are several links, with updates
spicyZ
08:17:15 10/30/13
If you upgrade to new type injectors also grind the >>>
ZUL8TR
11:32:10 10/27/13
