TwinTurbo.NET: Nissan 300ZX forum - Well it seems like you've checked a lot of complicated
300ZMang
on October 24, 2013 at 2:54 PM
Pressure checked the fuel rail as I was re-assembling
posted by ZTicket(Dallas)
on October 24, 2013 at 12:21 PM
items to identify this issue. Step back and think simple. Like Haasz32 said, just check other connectors. Is it making any crazy noises, or just doesn't want to hold an idle?
Still having idle issues after plenum pull. Fixed air
ZTicket(Dallas)
05:32:19 10/23/13
You still have an air leak somewhere, possibly
doug8867
06:36:37 10/23/13
/\/\/\/\ agreed... also how are you doing the boost vac test (n/m)
Medallion Man
09:49:33 10/23/13
Boost leak test with 5-10psi through the intake. That's
ZTicket(Dallas)
10:29:52 10/23/13
Have you done the usual checks like ECU diag and O2 test? (n/m)
spicyZ
13:14:35 10/23/13
At this point, it won't run on it's own long enough
ZTicket(Dallas)
13:44:01 10/23/13
Car doesn't need to be running for ECU diags
spicyZ
14:10:42 10/23/13
I was trying to focus in first on the things that I had
ZTicket(Dallas)
15:04:48 10/23/13
Fuel issue? Maybe your injectors are dumping too much
300ZMang
07:36:20 10/24/13
ZTicket(Dallas)
12:21:46 10/24/13
Well it seems like you've checked a lot of complicated -
300ZMang
14:54:38 10/24/13
No noises. Just won't hold idle. I'm going to backtrack
ZTicket(Dallas)
17:57:31 10/24/13
Maybe you mixed up a pair of injector or coil pack connector
Haasz32
14:15:51 10/24/13
The way the harness lays out, the correct connectors
ZTicket(Dallas)
18:01:55 10/24/13
My money is still on an air leak. Classic symptoms.
doug8867
21:41:40 10/24/13
I would agree with you, except for the fact that I
ZTicket(Dallas)
05:35:25 10/25/13
Re-check all vaccuum lines
spicyZ
08:47:52 10/25/13
That's what I wanted to hear. I'm going at it tomorrow
ZTicket(Dallas)
19:40:56 10/25/13
Make sure the underside of the throttle body hoses
doug8867
11:26:58 10/26/13
Got it running this morning. MAF a little cock-eyed due
ZTicket(Dallas)
14:31:46 10/27/13
Did you remove the IAA when you pulled the plenum?
doug8867
06:53:20 10/28/13
No, I left it attached. It was a relatively new
ZTicket(Dallas)
12:20:56 10/28/13
