TwinTurbo.NET: Nissan 300ZX forum - Just some key points to verify
Subject Just some key points to verify
Posted by -Grimm- on October 23, 2013 at 9:46 PM
  This message has been viewed 183 times.
In Reply To Re: I haven't read the attached procedure, but... posted by wild_maxx on October 23, 2013 at 08:29 PM
Message to rule things out...
-You are setting TDC (0*) on the same piston for which you are degreeing the exhaust valve on
-Your degree wheel is not slipping, pointer is not moving
-Your timing marks/tooth count seem correct
-You are measuring valve height from the valve itself (and setting 0 at full lift, meaning the 0.050" would be closing motion)
Any pictures?
