TwinTurbo.NET: Nissan 300ZX forum - Re: I spent 5 hours trying to bleed the clutch...
Subject Re: I spent 5 hours trying to bleed the clutch...
Posted by BlackTwins on October 23, 2013 at 12:55 AM
  This message has been viewed 226 times.
In Reply To I spent 5 hours trying to bleed the clutch... posted by MaxxAction on October 21, 2013 at 09:39 PM
Message hi , hope u replace the clutch slave n to let u know i went true it too. bleed alot , still not moving into gear.. this what i did... make sure ur clutch slave line is good. no rust or anything like that. that could cuz it to be bad. if u bleed the clutch few times n fluid leaking out the slave then u got a problem to check the lines or its defected . if there is autozone there to get parts its cheap . i had to replace my slave lines from the boot to the clutch slave . n then my pressure build up n works. good luck in fixing your z . let me know if any questions. .
