TwinTurbo.NET: Nissan 300ZX forum - is the timing and TPS adjusted correctly?
Subject is the timing and TPS adjusted correctly?
Posted by Zvil (FL) on October 21, 2013 at 1:05 PM
  This message has been viewed 220 times.
In Reply To Problem after Plenum Pull. Fixed my air leak caused posted by ZTicket(Dallas) on October 21, 2013 at 12:32 PM
Message if so I would say the solenoid for the IACV (yellow connector) is bad, the FIC (blue connector) is only for the A/C so it won't effect normal running. the way you can test your IACV solenoid is by applying 12v to it and if it clicks your problem is elsewhere, if it doesn't you'll need a new one. please report back with results!
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to impolitely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
