TwinTurbo.NET: Nissan 300ZX forum - It's not the silver sleeved tube, that has nothing to
Subject It's not the silver sleeved tube, that has nothing to
Posted by doug8867 on October 19, 2013 at 8:57 PM
  This message has been viewed 212 times.
In Reply To Boost leak question posted by 95TTurboZX on October 19, 2013 at 11:31 AM
Message do with the air system. However, your leak could be from the "J" tube that goes into the top of the turbo and it has come loose. It is attached to the turbo with a short rubber coupler and a hose clamp. Over the time the tube can work itself loose and needs to be wiggled back and forth and pressed down in the coupler and then the clamp tightened again. Unfortunately to access it, you will need to remove the intake piping on that side along with the ASCD bracket that holds the ASCD and solenoids and flip out of way to make room to access the screw on the hose clamp and the J tube. Removing the battery also helps to make it easier to access. Hope that helps.
