TwinTurbo.NET: Nissan 300ZX forum - Re: About to yank motor for turbos...Is it tired?
Z32twins
on October 19, 2013 at 2:07 PM
posted by Z32twins
on October 15, 2013 at 07:46 PM
Quick question: When the engine is out can you access the knock sensor for replacement without pulling the lower plenum?
Z32twins
19:46:51 10/15/13
While you're in there...
-Grimm-
09:40:26 10/16/13
100psi is the norm for a leak down test
ttsmokin
09:52:48 10/16/13
100 psi is used for easy calculating
-Grimm-
09:57:42 10/16/13
I would test at 100 psi. I don't know leak down testing,
zellamay
10:33:26 10/16/13
I'll add to this by saying
-Grimm-
11:19:57 10/16/13
Re: I'll add to this by saying
Z32twins
21:10:47 10/16/13
That philosophy can get expensive. Where do you stop?
zellamay
21:57:56 10/16/13
Re: That philosophy can get expensive. Where do you stop?
Z32twins
07:25:23 10/17/13
Just clean all the lifters. Dont bother looking for bad ones (n/m)
ZXoltan
17:15:46 10/17/13
Re: Just clean all the lifters. Dont bother looking for bad ones
Z32twins
09:27:02 10/18/13
Anyone else think carb cleaner is too volatile for lifters?
-Grimm-
11:59:08 10/18/13
Nah... the cleaner in the big buckets is not very caustic
ZXoltan
14:58:56 10/18/13
Re: About to yank motor for turbos...Is it tired? -
Z32twins
14:07:52 10/19/13
NO, I don't think so unless somebody has a procedure I
SammybTT(TN)
08:04:45 10/20/13
Yes you can - may need to remove EGR
spicyZ
10:23:37 10/21/13
2nd. (n/m)
Woody75 (Denver)
16:41:04 10/22/13
