TwinTurbo.NET: Nissan 300ZX forum - 100psi is the norm for a leak down test
Subject 100psi is the norm for a leak down test
Posted by ttsmokin on October 16, 2013 at 9:52 AM
  This message has been viewed 268 times.
In Reply To About to yank motor for turbos...Is it tired? posted by Z32twins on October 15, 2013 at 07:46 PM
Message Fairly certain using only 20psi will yield more "favourable" results. Repeat test with a proper air supply and do a compression test also. You don't want to pull the motor and install new chras only to find out that the rings were shot or the valve seals leaking etc etc
