TwinTurbo.NET: Nissan 300ZX forum - yes i do, ohm em? (n/m)
Khronik
on October 14, 2013 at 5:47 PM
Bosch is an OEM supplier to many makes
posted by -Grimm-
on October 14, 2013 at 05:33 PM
O2 Sensor Test Issue
Khronik
13:04:33 10/13/13
EDIT: is light OFF lean or rich?
Khronik
14:04:04 10/14/13
LED On -> Lean, Off ->Rich
-Grimm-
14:33:05 10/14/13
Also, was your engine up to temp? (n/m)
-Grimm-
14:33:50 10/14/13
engine was up to temp i went for a short drive prior
Khronik
15:25:38 10/14/13
Vacuum leak would cause you to run lean
-Grimm-
15:58:55 10/14/13
i do not (n/m)
Khronik
16:23:44 10/14/13
z1 non-oem o2 sensors
Khronik
16:45:24 10/14/13
-Grimm-
17:33:26 10/14/13
yes i do, ohm em? (n/m) -
Khronik
17:47:08 10/14/13
No, check the voltage
-Grimm-
09:19:33 10/15/13
