TwinTurbo.NET: Nissan 300ZX forum - Re: im starting to question the integrity of your posts
Subject Re: im starting to question the integrity of your posts
Posted by bleedingzzzz on October 13, 2013 at 2:28 PM
  This message has been viewed 260 times.
In Reply To im starting to question the integrity of your posts (n/m) posted by 300ZMang on October 13, 2013 at 11:15 AM
Message Like I said before in my posts... I did the swap and trying start the engine I found my first problem won't start and there's my first question.... Found bad injectors...in that time I check everything... (grounds, voltage..ECU, CAS,PTU) all the things I have to check first when won't start...now finally the car start but I have to set up the engine but now issues ....low oil compression!!!! I connect new gauge oil pressure brand prosport and read very low compression....... Then I check in the web about low oil compression..found some times if the pan is dent...probably gona have low oil compression,but not all the time ....now it's my question....if is my oil pan or probably my oil pum...and like I said to in my first posts to the engine is a JDM ENGINE....THANKS
