TwinTurbo.NET: Nissan 300ZX forum - Wont Start (motor re install)
Subject Wont Start (motor re install)
Posted by HKS Z32 on October 12, 2013 at 3:37 PM
  This message has been viewed 184 times.
Message If you have a z32 that is turbo And remove the engine for maintance then re-install it and afterwards & it does not start then here might be the dilemna
If all diagnosis points to no spark
Its not the PTU... It might be the ground wire on ignition side On driverside frame rail facing accordian pipe
My friend advised he forgot to reinstall before installing charge pipes and thought it would be easier to just ground it by the fuse box on the body.... That was wrong Make sure all oem grounds are in he oem locations
  • Wont Start (motor re install) - HKS Z32 15:37:50 10/12/13
