TwinTurbo.NET: Nissan 300ZX forum - PCV Re-route Question
Subject PCV Re-route Question
Posted by DJK-West on October 11, 2013 at 4:48 AM
  This message has been viewed 516 times.
Message So I've been reading up on this write-up so that I can do this relocation on my TT, [ http://twinturbo.net/nissan/300zx/forums/technical/view/1019112/The-ultimate-PCV-reroute-write-up.html ] .
In it, Woody75 basically capped off the ports on the driverside exhaust valve cover as shown in the pic below.
Then he drilled holes into the intake valve covers for new fittings for the new ventilation hoses to connect from and into the PCV valves on the plenum. Can we simply T-off from the existing tube coming from the intake valve cover to the accordion pipe for the turbo inlet and connect the T to the PCV valve on the plenum?? There won't be any unmetered air entering the plenum since the air moving thru the existing front PCV hoses are behind the MAF. Any suggestions will be great.
