TwinTurbo.NET: Nissan 300ZX forum - That is suspect, steering feeds HICAS controller
Subject That is suspect, steering feeds HICAS controller
Posted by ThisIsSparTTa on October 10, 2013 at 2:38 PM
  This message has been viewed 184 times.
In Reply To Re: Is the steering behaving correctly? posted by Dane (Houston) on October 10, 2013 at 01:54 PM
Message If your HICAS controller doesn't get a speed signal after 15-30 seconds it cuts out power steering.
From what you said, it doesn't sound related, but my Fleabay Consult>USB converter was somehow killing the speed signal to the HICAS and ECU, which was causing PS to cut out as a fail-safe. Speedometer still worked though. Unplugging consult, everything works fine.
