TwinTurbo.NET: Nissan 300ZX forum - If the valves are bent there will be slop...
Subject If the valves are bent there will be slop...
Posted by -Grimm- on October 09, 2013 at 4:21 PM
  This message has been viewed 246 times.
In Reply To Don't know about the Q45 belt but a J30 belt should work>> posted by ZUL8TR on October 06, 2013 at 08:32 AM
Message in the cam sprocket when you get to that cylinder lift sequence (depending on the amount of damage, other valves may be on the base lobe and the cam will basically rotate freely)
Also, I had a timing belt tensioner fail on my TT when I just put it back together and my belt slipped all over the place, and I was trying to start this thing for days. No valves got bent (thankfully) so there is still a chance.
Although the piston height on the TT is a bit less than the NA.
