TwinTurbo.NET: Nissan 300ZX forum - It can be done
Subject It can be done
Posted by Shiers69 on October 09, 2013 at 7:49 AM
  This message has been viewed 432 times.
In Reply To Front Lower Control Arm Bushing Replacement posted by ZXRider on October 08, 2013 at 03:32 PM
Message I did the burn out/cut out method on my rear LCAs and it worked pretty well - better than it did on the rear subframe.
I ended up not installing them - but the control arm bushings pressed in easily with enough of the supplied ES grease.
If you do it you might as well get the arms sand blasted and powder coated while you're at it. Keep 'em from rusting up.
