TwinTurbo.NET: Nissan 300ZX forum - and a pry bar did nothing? It may be hung up on the
jzack
on October 07, 2013 at 10:53 PM
Re: Bolt is accessed by rotating the belt pulley until the hole
posted by lukzzkeeper(philly)
on October 07, 2013 at 09:46 PM
bracket?
removing power steering pump
lukzzkeeper(philly)
13:07:59 10/07/13
Remove the pivot bolt and the adjustment hardware/arm. (n/m)
Woody75 (Denver)
13:17:18 10/07/13
but is that the 14mm bolt
lukzzkeeper(philly)
13:29:44 10/07/13
jzack
18:28:18 10/07/13
lukzzkeeper(philly)
21:46:16 10/07/13
and a pry bar did nothing? It may be hung up on the -
jzack
22:53:10 10/07/13
will try the pry bar when i get off work. (n/m)
lukzzkeeper(philly)
00:23:22 10/08/13
The high pressure hose is disconnect too, right? Had to ask (n/m)
jzack
18:52:12 10/08/13
You have to pull down to get it loose from
doug8867
06:33:52 10/08/13
THANKS FELLAS, i got it
lukzzkeeper(philly)
01:48:41 10/09/13
