If you're not leaking from anywhere else it's def your mc. Your 2ndary cup seal in primary piston is leaking, not holding pressure. Brake fluid is leaking past that seal back into the reservoir. A soft pedal with no visual leaks is a telltale sign. Also only non abs z's have diagonal primary and secondary hydraulic brake circuits
