TwinTurbo.NET: Nissan 300ZX forum - Re: still..won't start
Subject Re: still..won't start
Posted by yummy18268 on October 02, 2013 at 2:49 AM
  This message has been viewed 173 times.
In Reply To still..won't start posted by bleedingzzzz on September 30, 2013 at 03:17 PM
Message With key on engine off, and harnesses connected to the injectors, measure voltage drop at each side of the injector. You should get 12v on both sides. The only time u should get 0v on one side is when the engine is running. The ground side is controlled by the ecu. You wont be able to measure with a multimeter cause the freq of the pulses are too fast for the MM to pick up. Only a oscilliscope or scan tool can pick that up. If you dont get 12v at both sides, your injectors have an open in them, but i doubt all of them are bad. Doublecheck your grounds on your ecu.
