TwinTurbo.NET: Nissan 300ZX forum - OTHER symptoms of failing BMC?
Subject OTHER symptoms of failing BMC?
Posted by LJZTT on October 01, 2013 at 12:26 PM
  This message has been viewed 351 times.
Message The big one is a pedal going soft with pressure applied, meaning as you brake the pedal slowly goes to the floor.
Anything else?
I am looking to get my Z back on the road soon but I really want to resolve an issue I have with the steering wheel giving a pull to one side under any hard braking. T-rods are solid bearing, no cracks visible where they bolt to control arms, alignment is good.
I also cannot find any brake fluid leaks anywhere and the fluid level is normal.
I was told that it could be the internal seals not holding pressure and that if the Z32 is designed with diagonal brake circuits (meaning front left on same closed loop as rear right and vice versa) then a bad internal seal may be letting pressure out of one loop but not the other, therefore one side retains braking force and not the other up front resulting in the steering wheel pull.
Any input on this?
"What a curiosity our new political correctness has made of our public spaces. Let your sex tape loose on the Internet and be rewarded with your own TV show;
photograph a crucifix in a jar of urine and our museums will vie to exhibit it; occupy someone else’s property and you will be hailed by the president for your keen social conscience.
But call people who blow up, behead, and mutilate, “savage” — and polite society will find you offensive."
--Jared Silverman
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
--Winston Churchill
"When the people find that they can vote themselves money, that will herald the end of the republic."
--Benjamin Franklin
"Government is not reason. It is not eloquent. It is force. Like fire, it is a dangerous servant and a fearful master."
"The last official act of any government is to loot the treasury."
--George Washington
END THE FED
....learn why, in 42 minutes
Full Pardon for PFC Bradley Manning
