TwinTurbo.NET: Nissan 300ZX forum - shouldn't need to gap the standard NGK plugs..
Subject shouldn't need to gap the standard NGK plugs..
Posted by Medallion Man on October 01, 2013 at 9:22 AM
  This message has been viewed 246 times.
In Reply To Re: Re: Balance tube leak is one guess. There's a bracket posted by PYROhafe on October 01, 2013 at 07:34 AM
Message I would be more inclined to agree that their is either an air leak, something has been disturbed or the car needs re-adjustment after the new components.
have you checked and cleaned all connectors including MAF, TPS, PTU, injectors, coil packs, ecu temp sender unit & CAS?
you might need to re-adjust the tps and idle screw.
it would be good to check the timing and have conzult/ecu talk/nistune stats.
can't hurt to have a look at the 6P's
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=922678 ]
