TwinTurbo.NET: Nissan 300ZX forum - check the ecu connector in the 5spd... sometimes the
Subject check the ecu connector in the 5spd... sometimes the
Posted by Medallion Man on September 29, 2013 at 2:57 AM
  This message has been viewed 156 times.
In Reply To EDIT: ECU connection question posted by Rasta420 on September 28, 2013 at 07:17 PM
Message little prongs push back out and so don't make correct contact.
take the plastic cover of the back of the plug and carefully look.. also make sure when you put it back in that you only tighten it as much as required NOT as tight as possible as that can cause it to bow and loose connection. (but it must be bolted)
this might help for wiring ...
[ http://www.karljapetre.com/z/ecu/ ]
