TwinTurbo.NET: Nissan 300ZX forum - Zemulator...injector latency question
Subject Zemulator...injector latency question
Posted by MY3ZTT on September 28, 2013 at 4:05 PM
  This message has been viewed 196 times.
Message I've been trying to adjust my A/F at idle and have been having some trouble. I have PE850cc injectors with true dual MAF (SAFCII). Ash has sent me a baseline file and the car runs fine but the idle has never had a correct A/F. It always reads "lean" (I have a PLX M-300 WB).
Now I've emailed Ash and he has given me some advice, like adjusting the injector latency numbers but I'm not sure how to go about that because in the Zem, there is injector void and injector blast with their own numbers. The base file has the void at 90ms and the blast at 75ms. I've adjusted the blast to about 100ms and saw no difference with A/F. I even went up to 120ms to see if that had an effect and nothing happened except reading "lean"
Anyone out there using the Zem have any insight or even others who know about adjusting the injector void/blast numbers. I just don't know how to adjust both numbers to get an effect. Thanks for your help.
  • Zemulator...injector latency question - MY3ZTT 16:05:53 09/28/13
