| Message |
I bought a 90 NA 5spd with TT swap in progress, has a new engine harness, 2 ECU's. The stock NA ECU and the TT ECU. When I connect my Consult cable to the port and turn the key on the dash lights come on but no CEL light, I cannot get the Consult cable to read the ECU. I also have a 91 NA 2+2 and it works fine on that car, so the cable is known good. What I want to know is what all wires need to be connect, grounds, sensors, etc to at least establish a connection to the ECU through the data port? Thanks Rasta420
