TwinTurbo.NET: Nissan 300ZX forum - wheels slightly pointing diff directions
Subject wheels slightly pointing diff directions
Posted by Va5hTheStampede on September 19, 2013 at 9:11 PM
  This message has been viewed 140 times.
Message Problem is this, I have replaced:
Front suspension.
-Lower control arm
-tension rod
-upper control arm
-shocks and eibach lowering springs
-300degree camber kit
I took it to get an alignment a few days ago after replacing the lower control arm, also I saw the front wheels were pointing slightly diff directions, so I told the alignment guy he put the car on the lift and wedged a large screw driver against some parts to check if they had give, but after 20 mins of searching for some extra play he gave up and just ended up aligning the car, I saw the car right after and it was normal, it has been two days and I looked at my wheels today and I saw it was back to pointing in diff directions,
I suspect it is a problem in the passenger sided front wheel,
it is the main reason I replaced the lower control arm it was(it had more camber than the other side, that problem is gone now). there is also a small but noticeable crack sometimes coming from the front right side, happens only sometimes, sometimes when I brake sometimes when I turn, it also looks slightly lower on the right side,
I have no idea what else it could be, I checked all nuts and bolts, the steering rack it has good bushings, and boots, no extra loose ball joint or anything.. anyway let me know what you guys think sorry for the long message
