TwinTurbo.NET: Nissan 300ZX forum - Crank bolt: put the right size socket on a breaker bar
Subject Crank bolt: put the right size socket on a breaker bar
Posted by zellamay on September 16, 2013 at 11:55 AM
  This message has been viewed 378 times.
In Reply To No, they are cylinders 2 and 3... opposite banks posted by 300ZMang on September 16, 2013 at 09:30 AM
Message then lay the bar on the frame or on the ground. Put a piece of plywood behind the radiator to protect it in case the socket slips off. Then use the ignition to hit the starter for one second. ..... I wonder if the drive belt on the water pump was too tight. I wouldn't guess any head gasket leak would damage the pump. I've had 2 cars with HG leaks and no water pump damage.
