TwinTurbo.NET: Nissan 300ZX forum - Look at the back of the crankshaft for the rod bearing
Subject Look at the back of the crankshaft for the rod bearing
Posted by ztunerz on September 16, 2013 at 12:28 AM
  This message has been viewed 222 times.
In Reply To Connecting Rod Bearing Grade Stamps posted by -Grimm- on September 15, 2013 at 04:50 PM
Message Grades. You need to add those to the numbers on each rod big end. For example if the crank says 1 1 2 1 2 1 and every rod says 0g0 your final grades would be 1 1 2 1 2 1.
The front of the crank referees to the main bearings. You need to add those numbers to the numbers etched into the block next to the girdle.
Formerly yellowzxtt
