TwinTurbo.NET: Nissan 300ZX forum - Re: main bearing grade determination
Subject Re: main bearing grade determination
Posted by aliaZ on September 15, 2013 at 9:27 PM
  This message has been viewed 173 times.
In Reply To main bearing grade determination posted by tian2bing on September 15, 2013 at 08:32 PM
Message :my thought was:
:If I make the bore to fit 87.25mm pistons, the crankcase journal's engraving (in my case: 2222) no longer matters.
Your thought is incorrect. Your cylinder bore does not have any input into your bearing grade determination
:Since the main bearing grade is determined by adding this journal number to the what's engraved on the crankshaft's counterweight, how am I going to determine the main bearing grade now?
? Why not add the journal number to what is engraved on the crank?
:Also, do i have to grind the counterweight considering the new 87.25 mm piston would weigh different than the original?
You need to have your machine shop balance the assembly. This isn't something you do with a dremel
