TwinTurbo.NET: Nissan 300ZX forum - It would if the vacuum leak is on the wastegate lines (n/m)
-Grimm-
on September 15, 2013 at 6:56 PM
Re: It also pulls 10-11lbs of vacuum used to pull 19 or so
posted by fastrnu90
on September 15, 2013 at 06:36 PM
Idle/running problems
z-u-later
15:35:31 09/15/13
It also pulls 10-11lbs of vacuum used to pull 19 or so (n/m)
z-u-later
15:53:58 09/15/13
fastrnu90
18:36:35 09/15/13
It would if the vacuum leak is on the wastegate lines (n/m) -
-Grimm-
18:56:55 09/15/13
I did one about 3 months ago, boost leak that is. (n/m)
z-u-later
20:19:50 09/15/13
z-u-later
16:49:31 09/16/13
I think you mean inches of mercury, not pounds
aliaZ
21:36:54 09/15/13
yes you're right i just didn't (n/m)
z-u-later
07:30:32 09/16/13
Or mTorr :) (n/m)
-Grimm-
17:07:03 09/16/13
Re: I think you mean inches of mercury, not pounds
fastrnu90
19:19:24 09/16/13
ever do a compression test? could have bent valves (n/m)
300ZMang
18:33:17 09/18/13
