TwinTurbo.NET: Nissan 300ZX forum - Re: AC retrofit question
Subject Re: AC retrofit question
Posted by 1bad300t.t. on September 15, 2013 at 2:39 PM
  This message has been viewed 257 times.
In Reply To AC retrofit question posted by arkansasturbo on September 15, 2013 at 01:34 PM
Message Do a search for Evan Wright. He did a write up on this a few years back. Also Aliaz can answer all your questions on a/c concersions. Im going to be doing the same this winter and Aliaz said to go with the later '94-'96 condensor. Also replace the drier and recomended replacing the evaporator to the later models as well. Which you will need the case and all. The old evaporators have a throttle suction valve that wont work with 134. Also need to flush out mineral oil from all the lines and install ester oil along with flushing compressor as well. But look up Wright's post and it will explain it all and parts needed.
