TwinTurbo.NET: Nissan 300ZX forum - might just be the ECU cold-start timing
Subject might just be the ECU cold-start timing
Posted by zromtech on September 13, 2013 at 11:06 AM
  This message has been viewed 274 times.
In Reply To Cold Start Hesitation posted by CO_Engineer on September 11, 2013 at 07:36 PM
Message This behaviour could also just be the ECU cold-start ignition timing. On cold-starts the ECU uses different maps and retards the ignition timing quite a bit below ~2500rpm until the coolant temp hits 55°c. The colder it is, the more the timing is retarded. This is most likely to help heat up the cats/turbos faster in cold conditions.
Try logging your ignition timing and coolant temp via Consult and see if the hesitation instantly goes away at 55°c.
